Problem with Asset Premium R7 for Raspberry Pi V4: Search-field "Style" doesn't work
  • forumme
    • Nov 2020
    I use Asset-UPnP 5.1 on a Windows Home Server with a big search-tree without any problems. The same search-tree works fine on an "orangepi-System" with Asset-UPnP 5.1 for Debian-Linux.
    Now I changed from orangepi to Raspberry Pi V4, using Asset-UPnP-Premium R7. But now the same search-tree shows problems, because the implemented search-field "Style" doesn't work. Independent where "Style" is placed.Under "Style" is always shown nothing. All other used fields like Genre, Composer, Album Artist are O.K.
    So I think,it's a single failure that "Style" is not programmed proper.
    I am wrong? Thank's for any solution.
    ... it is very important for me to solve this Problem, because I have a library of 350 GB an I can't change every item for eleminating/changing "Style"
    Best regards
  • sjbabbey
    • Apr 2014
    • 69
    Re: Problem with Asset Premium R7 for Raspberry Pi V4: Search-field "Style" doesn't w
    See this subject:
    I use the "Style" tag in mp3tag to indicate the format of my individual albums i.e. whether mp3, CD or HR (Hi-Res). However, if I open the "Style" category now in Asset I see the name of the Artist (or Album Artist - not sure which) instead. All releases prior to R7 have shown the correct data. Looking more
    The problem is that the "Style" datafield went missing in the R7 release. You need to go into config\Advanced\Edit database fields (advanced users only) and manually type in the word "style" at the bottom of the long list of data fields then "Apply" and Asset should rescan your library.
    You will need to do this procedure for each "Instance" if you have more than one.
    • forumme
      • Nov 2020
      Best regards
      ___________________________________________
      PROBLEM IS SOLVED; read the dokumentation!
