Crash After Changing Audio Library Folders
  • dypsis
    • Nov 2008
    • 61
    Hi.
    Asset UPnP crashed when I changed Audio Library folders.
    Crash dump is attached.
    • 46231
    Re: Crash After Changing Audio Library Folders
    What exact steps did you take for it to crash? you changed the path in the config and it asked to restart asset, then it crashed?
    • dypsis
      • Nov 2008
      • 61
      I removed an existing folder, then I added two other folders.
      • dypsis
        • Nov 2008
        • 61
        It has crashed again.
        I removed the "Ratings" folder by clicking "Remove Selected", as I don't use ratings.
        I was presented with the message that it needs to restart, and I clicked "Yes". And I think I clicked on "OK" on the other screen, and I think that's when it crashed.
Name:	Asset UPnP Crashed.png
        Crash dump attached.
          • 46231
          We would need to build a special test version, please email us at the address here:
