Asset on Synology NAS for Sonos - issues
  • Balderick
    • Dec 2013
    • 55
    I thought I had Asset figured out but am having a issue using Sonos on my Synology NAS (or for that matter same issue on Asset for PC)
    The issue is that There is no option to PLAY the entire folder when we look at the music. Yes, we can play a single song, but only one song. I'm sure there is some setting I'm not finding, but at this point MY SOnos can only play one song from any folder.
    I only play through folders, everything else is just a mess. (Genres, Artist, Albums, etc. all a complete waste of time) I ripped all of my 500 CD's with the same settings via dBPoweramp CD Ripper and still they are nothing more than a mess. But this is another issue, and beside the point of this thread.
    Is ther anything I can change to fix Asset to allow to play the entire folder? I can do it on other units such as my Simaudio Moon MiND... Just not on Sonos.
    • 46231
    Re: Asset on Synology NAS for Sonos - issues
    It is more to do with the sonos controlling app, try adding the tracks to a playlist on the app to play?
    • Balderick
      • Dec 2013
      • 55
      I kind of figured that, though I had a similar problem with BubbleUPnP where it would not play the contents of a folder. This has to be connected. I don't have any inclination to make playlists for a thousand FLAC folders.... Christ, that's half the point of having server software. If one control point app will do it then another has to be able to. It only seems logical.
      Thanks for the reply Spoon. May have to go onto Minimserver or something else... It seems that EVERY server software pkg has some issue or another. The Synology one does as well (completely different issue)
