Big problem with Asset 6.3
  • ynaim2
    • Jun 2016
    • 14
    Hello I have a lot of problem recently with Asset 6.3 on MacOs 10.14.6 .Probleme playlist with message that says my server is not plug and also server not found. I try to remove Asset and reinstall nothing to do. This problem started with Asset 6.2 does the problem come from MacOS? or network. The problem is very disagreeable is that someone has a please.
    Thank you .
    • 46231
    Re: Big problem with Asset 6.3
    What is creating the error message, your player?
    • ynaim2
      • Jun 2016
      • 14
      The message I have is server not found on my Naim device as much as on the application. I managed to find the server after several months. Open Farm Asset, open closes the wifi ect.
      I never had that kind of problem. tanks for your help.
        • 46231
        It is likely something is blocking Asset from the network, what security software do you have?
        • ynaim2
          • Jun 2016
          • 14
          Bitdefender for Mac
            • 46231
            try disabling it
            • ynaim2
              • Jun 2016
              • 14
              Well, I've deactivated my antivirus same result is a very weird result of this situation. Could it be a port of port open or close on my router?
              Thank you.
              • ynaim2
                • Jun 2016
                • 14
                How do I start fresh from scratching everything is all reinstalled can be that it settles my problem ?
                Tanks
                  • 46231
                  Uninstall Asset, reboot OS X (full shutdown), then reinstall from the link in the registered email.
                  • ynaim2
                    • Jun 2016
                    • 14
                    Is asset compatible with Catalina?
                      • 46231
                      Yes
