Start-Up Issues
  • NoFeedback
    • Oct 2019
    Start-Up Issues
    I am using Asset UPnP REv 6.2 on a Windows 10 laptop and playing music from a DLNA compatible Yamaha BD-A1060 Universal Disc Player. I can access the Asset via WiFI from the player and view the music folders but none of the folders show the music files that are present in the folders (generally FLACs). All that shows up in music-containing folders is the "back" folder.
    I turned on the Windows DLNA and everything works as expected from the player, the music files are shown and play normally.
    Any idea why the Asset server isn't showing music files?
    Thank you,
    Mike
  • timster67
    • May 2014
    • 210
    Re: Start-Up Issues
    A problem with the tagging? Or are you using folder view?
      • 45836
      Re: Start-Up Issues
      You would have to try a different control point to browse asset, try this:
      Asset Control (a UPnP / DLNA control point) is billed as the control point you have been waiting for . In UPnP there are: Server / Control Point / Renderer, where the Server catalogues tracks, Control Point creates playlists from the Server and controls the Renderer (player), all 3 elements of UPnP could reside on the same
      • NoFeedback
        • Oct 2019
        Re: Start-Up Issues
        https://forum.dbpoweramp.com/showthr...-Asset-Control
        Asset Control finds the music files in Asset UPnP and Windows DLNA servers without any issue.
        The question remains as to why the Yamaha player finds the albums but displays no songs when accessing Asset UPnP directly.
        Mike
          • 45836
          Re: Start-Up Issues
          Perhaps only Yamaha have that answer.
          • NoFeedback
            • Oct 2019
            Re: Start-Up Issues
            I like the Asset Control App and it doesn't seem to have any problem playing my CD rips. When I play purchased 192kHz/24bit FLAC files, AC crashes during the playing of a song and then playing stops at the end of the presently playing track. If I subsequently click on the AC App screen, I get the spinning blue circle and Windows 10 eventually prompts to close the App. This can happen after the first track or any other track. Usually, it will crash within the first few tracks. I don't see any overloading issues when I look at the Asset tasks in the Task Manager.
            Any ideas?
            Mike
              • 45836
              Re: Start-Up Issues
              I am sorry to say Asset Control is no longer developed.
              • NoFeedback
                • Oct 2019
                Re: Start-Up Issues
                Oh, OK, that makes sense. I appreciate your help! I found a good Android Controller and upgraded my Asset UPnP server so I expect that I am "all set".
                Thank you,
                Mike
                • RaspberryAsset
                  • Feb 2018
                  • 43
                  Re: Start-Up Issues
                  I am using a Yamaha with Asset and no problem at all. What Yamaha are you using and what file format are you using for most of your music?
                  • NoFeedback
                    • Oct 2019
                    Re: Start-Up Issues
                    I am using a Yamaha BD-A1060 Universal Disc Player. Most of my music files are FLAC format. Most from CD rips and a number of 192kHz/24bit files.
