2 Asset problems, probably my doing something wrong...
  • kerryalt
    • Jun 2018
    2 issues have recently cropped up.
    First, Asset keeps falling off of my network. I'm running a 3 node google mesh network. I've rebooted everything multiple times, but Asset is not visible in mConnect or VLC unless I turn off WiFi, then restart WiFi. Then its visible and works fine until I stop music for a while. Then its not visible on the network and I have to reset WiFi again.This is new behavior, its been running fine for over a year. I'm running Asset R6.2 premium.
    Second, just purchased an album that was all .wav files. Assed doesn't find it in the same folder everything else is that Asset finds just fine. I thought it might be the .wav extension, so I used dbConvert to convert all the .wav to Apple Lossless, and Assed still doesn't find the album, even though I explicitly added the album folder in the Asset configuration.
    Any ideas? What am I missing?
    • 46151
    Re: 2 Asset problems, probably my doing something wrong...
    Your new album, it will need ID tagging, select the tracks >> right click >> Edit ID Tags
    Have you recently updated Asset? something has likely changed, either the network, security software, or Asset.
    • kerryalt
      • Jun 2018
      Nothing new on the network since I upgraded Asset months ago. Is there a network timeout setting somewhere I could check? Or something to look for in the logs?
      But you are correct on the ID tagging, they were missing.
