Guidance on Library and Settings Override Scripts.
  • JasHDahi
    • Jul 2012
    • 37
    I am hoping someone has more examples of overrides for settings and script for library exclusions as unfortunately the few provided are not helping me achieve my objective.
    I have a few different streamers in the house all using an AssetUpNp library on a Pi3 with USB HDD attached.
    Some of my streamers are able to play everything i have irrespective of quality while others are only capable of streaming CD quality (lossless FLACs).
    I believe the answer is to either script "Settings Override (Control Point Specific)" to have certain streamers reencode on the fly, or alternatively script the "Library Exclusions" and use 2 libraries, one for All and the other to only show less than a certain quality file.
    Can anyone help?
    Cheers Jason
    • 46162
    Re: Guidance on Library and Settings Override Scripts.
    The override is based on control point, not player, so if using the same control point for all players it will not work.
    A simpler way is to create new asset instances and change the settings there, then choose the different asset instance for each player.
    • JasHDahi
      • Jul 2012
      • 37
      I did plan to use a separate library, would utilising one where the "Stream As" setting for FLAC being set to WAV ensure that only 44/16 streams are delivered to the Pi/DAC combination I need it for?
      • JasHDahi
        • Jul 2012
        • 37
        I have set up another instance of asset but can't see how to force flacs to re_encode to 44/16, help?
          Have a look at Asset UPnP Help > Configuration Options.
          • JasHDahi
            • Jul 2012
            • 37
            That was my first point of call, so what are you actually pointing me at with your suggestions that answer my question please?
            The options allow a setting of 16bit and 48khz, as I stated I cant see a 16/44. My Arcam rDAC is stuttering for all FLAC and WAV files that are not standard CD quality.
              • 46162
              Edit advanced settings (for the selected instance) >> set 'Audio Format Streaming' Flas 'as wav'
              set the 'maximum' to '44KHz' '16 bit' '2 channels'
              • JasHDahi
                • Jul 2012
                • 37
                There are only 3 options available: 48, 88 and 96KHz?
                I've tried 48 and still get stuttering audio.
                The release version is shown as R6.2
                  • 46162
                  There is such litttle difference between 44KHz and 48Khz in terms of bandwidth, the stuttering is likely because of wireless is used. You can use a wired connection?
                  • JasHDahi
                    • Jul 2012
                    • 37
                    Thank you all for the support - am now sorted with the full range of resolutions actually working.
                    I already have a wired network and so tested this methodically as the next stage.
                    Turned out to be an issue with the switch port in use and simply changing ports (a switch reboot may have had the same result!) rresolved not just stuttering but negated the need for a seperate library instance too!
