Track order has gone alphabetical - help!!!
  • uncl_nigel
    • Aug 2017
    • 26
    I took delivery of a new streamer/DAC today and at some stage this evening the Asset software defaulted to alphabetical sorting of the tracks within an album. Normal order is defined by track number.
    I have found nothing to twiddle with in "configure" - when in doubt I leave well alone.
    - I am running Asset on a Mac
    - the control app is dCS Mosaic (this is quite new so the previous dCS app is still available and it manifests the same problem)
    - I have tried updating from 6.1 to 6.2 the problem remains
    - with a different (and less attractive) server software package the problem does not exist "Goodbye Yellow Brick Road" starts with Funeral for a Friend as it should
    How do I get the track order back?
    • 46189
    Re: Track order has gone alphabetical - help!!!
    Asset gives out in the order which is correct, however the control point can resort. You could try putting the track number into the track listing (option is called [track ] - [title] for album tracks, check this option).
    • uncl_nigel
      • Aug 2017
      • 26
      The option is checked the songs are displayed in the streamer app in the normal album order but played in alphabetical order of title - very annoying.
      This does not happen with the other (rather "rustic") upnp server software I installed last night.
      I would rather not change software but I am used to hearing songs in the order they have on the original media!
        • 46189
        I do not know of any player which would display in one way, yet play in another order. Very strange.
        • uncl_nigel
          • Aug 2017
          • 26
          And extremely annoying!
          I would rather not have to change software - I like Asset - but I need a solution
            • 6188
            It seems it is not ASSET that is the issue, but your player. Does seem like an odd problem.
