Problems Asset UPnP with Qnap QTS versions over 4.3.4.0695 and ATOLL ST200 streamer
  • julius_90100
    • Apr 2019
    I've got a Qnap HS-251 NAS, I hear my music on a ATOLL ST200 high quality streamer connected with Asset UPnP R6.2 installed on my Qnap.
    But there are problems to edite folders and files on the streamer about all versions up to 4.3.4.0695 of QTS firmware.
    Both ATOLL and Qnap software are right in conception. The problems seem to come from Asset UPnP compatibility with QTS last versions.
    Is anybody know something about this ?
    • 46231
    Re: Problems Asset UPnP with Qnap QTS versions over 4.3.4.0695 and ATOLL ST200 stream
    Sorry, what do you mean by edite the folders?
    • julius_90100
      • Apr 2019
      Asset server appears few many time and disappears anormally. Now it is a strong problem cause I must now update my Qnap to the last version of firmware. Because I have too mush probems on my network. I had contacted Qnap, they answer me that the problem is due to the Asset UPnP software. Please, could you find a solution.
        • 46231
        What type of problems?
        • julius_90100
          • Apr 2019
          When Firmware of Qnap server is not update, the differences of updates between Windows, Mac and Qnap make troubles in connexions with Qnap sever.
          But the problem is resolve. It was a problem of Qnap frimwares. The last one is OK but Qnap team told me nothing. Contrary to what Qnap said me on december 2018 the problem was in their firmware softwares.
          Thank you for your help.
          Best regard.
