Asset R6.2 does not send composer
  • operaticduck
    • Mar 2019
    after updating to R6.2 (QNAP) the composer is no longer displayed on the "Now Playing" tab of my Bubble DS. Does Version R6.2 no longer send the composer?
    Regards
    Super Moderator
    • 1371
    Re: Asset R6.2 does not send composer
    Problem being investigated, thanks for reporting.
      Super Moderator
      • 1371
      Fixed in today's beta-
      Current version: R6.3 beta 4 Download links: Mac: https://www.dbpoweramp.com/beta/Asset-R6.3b4.dmg QNAP: https://www.dbpoweramp.com/beta/Asset_R6.3b4.qpkg Synology: https://www.dbpoweramp.com/beta/Asset-R6.3b4.spk Linux x86 32-bit: https://www.dbpoweramp.com/beta/Asset-R6.3b4-Linux-x86.tar.gz Linux x86 64-bit: https://www
      Note: If you're a registered user, the beta will function as registered if installed over your existing Asset installation.
      • operaticduck
        • Mar 2019
        Installed the beta, works perfectly.
        Thank you!
        • Galileo58
          • Sep 2019
          I'm using Asses R6.2(QNAP TS 119 PII) and I have installed the R6.3 beta 4 over the R6.2 to fix the Composer tag problem. There were no installation erros, and Asset R6.3 beta 4 can be started/stopped in QTS 4.3.3. However,the App is not operational and visible as UPnP Server.
          Restarting the NAS does not fix the problem. So I had to go back to R6.2.
          So far I never had problems with new Asset releases. Could you please provide an official R6.3 release to fix the Composer tag problem? Thanks.
          • Mike-B
            • Aug 2018
            • 179
            For your info: - I've installed R6.3-b4 on Synology
            Its all working OK
