Raspberry Asset 6.2 - Elton John Index
  • RaspberryAsset
    • Feb 2018
    • 43
    Hi
    I notice that some artists are being indexed different then others. Joe Cocker is listed as Under J- Joe but Elton John is listed as Elton John under J and not E for Elton.
    I have checked the files it looks like the meta tags are correct.
    There may be others but this is the first one I have found.
    I did not notice this with the earlier version.
    Is there a setting I have missed?
    • 46231
    Re: Raspberry Asset 6.2 - Elton John Index
    You must have an artist sort tag (for any of the Elton john files).
    • RaspberryAsset
      • Feb 2018
      • 43
      Spoon you were correct! Thanks. I could not see anything wrong until I went into the edit custom sort values. Sure enough it was set to John,Elton
      Thanks so much.
