Shortcut problem with custom tag (on QNAP)
  • timster67
    • May 2014
    • 210
    Following on from this thread: https://forum.dbpoweramp.com/showthr...467*post187467
    I have my Favourites custom tag (either set to 1 or non-existent)in the browse tree thus:
    Favourites{_no_track_list_}
    Favourites\Album
    Favourites\Jukebox Album Selection
    Favourites\Jukebox Track Selection
    All fine.
    I have however also tried to add a shortcut thusly:
    Favourite Albums**Favourites&+&1&+&Album
    However, this lists all my albums, not just the ones tagged with my "Favourite" custom tag (it also lists them by alpha grouping, but doesn't have {_a_to_z_} so I don't know why it should behave differently).
    If I have the shortcut as before (Favourite Albums**Favourites&+&1) then this works as expected (simply skipping the "1").
    Basically I want to be able to go straight to the Favourites\Album listing, non alphs-grouped, but can't get it to work.
    Any help please?
    • 46189
    Re: Shortcut problem with custom tag (on QNAP)
    If you have:
    What is shown on the screen? what happens if you manually select album? it lists correct?
    • timster67
      • May 2014
      • 210
      If you have:
      I get Album, Jukebox Album Selection, and Jukebox Track Selection. Clicking into Album I get all my "favourite" albums listed (not alpha-grouped), as expected. Adding the &+&Album seems to be where it's going awry.
        • 46189
        Try:
        &+& Album
        • timster67
          • May 2014
          • 210
          Try:
          &+& Album
          I tried that before - the control point (Linn Kazoo) just shows an endless spinning circle.
          • timster67
            • May 2014
            • 210
            Any progress on this? Or is it just not possible for some reason?
              • 46189
              We would have to test for this, it is likely next time we update Asset.
              • timster67
                • May 2014
                • 210
                Ok, thanks Spoon
                  • 1650
                  Should be fixed in R6.7 beta-
                  This is the final maintenance update of R6 series. R7 is being worked on. Current version: beta 1 Downloads: QNAP: https://www.dbpoweramp.com/beta/Asset_R6.7b1.qpkg Synology: https://www.dbpoweramp.com/beta/Asset-R6.7b1.spk ARM 32-bit / old R-Pi: https://www.dbpoweramp.com/beta/Asset-R6.7b1-Linux-ARM32.tar.gz ARM 64-bit / new
