Creating MP3 & FLAC Cross-compatible Custom ID Tags for Asset
  • kkhan
    • Nov 2017
    • 12
    I have been experimenting with custom ID tags for my classical music collection now that Asset allows multiple instances. I followed the instructions in the sticky post (https://forum.dbpoweramp.com/showthr...-Tags-to-Asset) but have hit a snag. Custom tags appear to be handled differently in mp3 and FLACs.
    Using MediaMonkey (v4.1.23) (and a hex editor for diagnostics) I created a custom tag as a frame (CUSTOM1) with the intention of using it to capture the solo instrument(s). In FLAC it creates a frame called CUSTOM1. Following the sticky instruction, I was able to get Asset to recognise it.
    However, Mediamonkey creates custom tags differently. It embeds the custom tag within a Comment frame as COMM = (music-db_custom1 value1 value2 etc). Apparently, this is part of the ID3v2.3 standard but can I handle this in Asset while maintaining cross-compatibility with FLAC files in my collection?
    In summary, for FLACs it creates a Frame for the custom tag while for MP3s it uses the COMM frame and embeds the custom tag within it.
    I had a look at an alternative tagger Mp3Tag but again a similar issue arises. I can create a custom tag as a frame called INSTRUMENT in FLAC. However, for MP3s it embeds the tag within the TXXX frame (user defined text information frame) as TXXX = (instrument value1, value2 etc).
    Is there anyway I can get handle this issue - any advice would be welcome.? If not the only workaround I can think of is to re-purpose an existing unused frame which is common to MP3s and FLACs.
    • 44052
    Re: Creating MP3 & FLAC Cross-compatible Custom ID Tags for Asset
    The comm is part of the standard however 'music-db_' is not, you need a tagger which will write just 'custom1', try dBpoweramp, right click on the file(s) >> Edit ID Tag.
    • kkhan
      • Nov 2017
      • 12
      Thanks Spoon. I will give that a try.
      I have another question regarding advanced tagging. I would like to use the IPLS tag (Involved Persons List Series) tag to capture musicians by primary instrument for my classical collection. I can do that quite easily using MediaMonkey and Mp3Tag (and I hope using dbpoweramp...) but how can I get Asset to use that data?
      Thanks for any assistance.
      Also like to say that Asset gives many many hours of pleasure. A great piece of software.
        • 44052
        In dBpoweramp you would have to take an existing tagged file, right click >> Edit Tags, this is how Asset would read the tags. Then you would have to change the config for Asset to add this new database field, see:
        These are instructions for the Windows version. For Linux/Mac/QNAP, see below. Asset has the ability to display custom ID Tags (non-standard), with a little configuring. For example your FLAC library contains a unique tag of 'MOOD', you can add this to asset by: Start >> Run >> Regedit: Browse to:
