How to re-index?
  • dasion
    • Sep 2018
    How to re-index?
    I would like to know how to re-index. Please excuse me if this is posted somewhere, I did try to find it but without success.
    I have done a lot of cleaning up of tags of my music library, and I have found some old tags "stick" even when deleted. Specifically, for some files I had the artist tag incorrectly named and deleted it, wanting to have it blank. But the old artist tag still showed up on Asset (not my tagger and I checked in file properties to be sure), even after restarting Asset and rescanning. To debug, I rewrote the artist tag with some random characters and these random characters showed up in Asset. However, when I erased the random characters to leave the artist field blank again, the original incorrect artist tag showed up again. I am assuming this is because of old indexes that aren't getting cleaned out and getting reassigned to the file.
    I hope there is an easy way to do a fresh re-index without creating a new asset instance.
    Thank you
    • 46233
    Re: How to re-index?
    On the settings page there is an option to Rescan (refresh all).
    • dasion
      • Sep 2018
      Yes, but does this create fresh indexes from scratch? Unless, I am misdiagnosing, re-scanning isn't cleaning up orphan indexes left over from old data. I have re-scanned several times with no success. I did do a test with one folder on a new asset instance, and the new instance left the artist fields blank, as I wanted. I could just delete the old instance and create a new one but then I would have to redo my tree.
      Do you think this is a index problem? or something else?
        • 46233
        'Refresh All' it clears the database and starts refresh.
