ForceToSingle in Control Point Overrides does not work
  • asset-user
    • Nov 2018
    • 21
    it seems that the option ForceToSingle works when selected in the general (Control Point independent) settings (AssetUPnPForceSingle.txt), but it does not work in Control Point Overrides. ForceToMP3 works everywhere.
    Environment:
    • Asset UPnP version R6.2 beta 12 [Linux-ARM32] (Raspberry Pi)
    • The file AssetUPnPForceSingle.txt is empty.
    • User-Agent: FSL DLNADOC/1.50 UPnP Stack/1.0
    1.) ForceToSingle does not work
    OverrideSettings.txt
    Code:
    =FSL
    [ForceAlbumArt=480]
    [ForceToSINGLE]
    .flac
    .m4a
    .mp3
    a.) Selection of a FLAC album
    Code:
    <DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"  xmlns:dc="http://purl.org/dc/elements/1.1/"  xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"  xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/">
    <item id="d544576185538479099-co4B5237296F65FF9E" parentID="co4B5237296F65FF9E" restricted="0"><dc:title>  1   Findet Dorie 01</dc:title><res duration="0:03:40.000"
          protocolInfo="http-get:*:[B]audio/x-flac[/B]:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=03700000000000000000000000000000">http://192.168.178.41:26130/content/c2/b16/f44100/d544576185538479099-co4B5237296F65FF9E.flac</res><res duration="0:03:40.000"
          protocolInfo="http-get:*:[B]audio/wav[/B]:DLNA.ORG_PN=WAV;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=03700000000000000000000000000000">http://192.168.178.41:26130/content/c2/b16/f44100/d544576185538479099-co4B5237296F65FF9E.forced.wav</res><res duration="0:03:40.000"
          protocolInfo="http-get:*:[B]audio/L16[/B]:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_CI=1">http://192.168.178.41:26130/content/c2/b16/f44100/d544576185538479099-co4B5237296F65FF9E.forced.l16</res><res duration="0:03:40.000"
          protocolInfo="http-get:*:[B]audio/x-flac[/B]:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=03700000000000000000000000000000">http://192.168.178.41:26130/content/c2/b16/f44100/d544576185538479099-co4B5237296F65FF9E.flac</res><upnp:class>object.item.audioItem.musicTrack</upnp:class></item>
    b.) Selection of a M4A album
    Code:
    <item id="d-614983795286164148-co63DA51CDFC7782FA" parentID="co63DA51CDFC7782FA" restricted="0"><dc:title>  9   Wind_Air2</dc:title><res duration="0:01:04.000"
          protocolInfo="http-get:*:[B]audio/mp4[/B]:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=03700000000000000000000000000000">http://192.168.178.41:26130/content/c2/b16/f48000/d-614983795286164148-co63DA51CDFC7782FA.m4a</res><res duration="0:01:04.000"
          protocolInfo="http-get:*:[B]audio/wav[/B]:DLNA.ORG_PN=WAV;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=03700000000000000000000000000000">http://192.168.178.41:26130/content/c2/b16/f48000/d-614983795286164148-co63DA51CDFC7782FA.forced.wav</res><res duration="0:01:04.000"
          protocolInfo="http-get:*:[B]audio/L16[/B];rate=48000:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_CI=1">http://192.168.178.41:26130/content/c2/b16/f48000/d-614983795286164148-co63DA51CDFC7782FA.forced.l16</res><res duration="0:01:04.000"
          protocolInfo="http-get:*:[B]audio/mp4[/B]:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=03700000000000000000000000000000">http://192.168.178.41:26130/content/c2/b16/f48000/d-614983795286164148-co63DA51CDFC7782FA.m4a</res><upnp:class>object.item.audioItem.musicTrack</upnp:class></item>
    c.) Selection of a MP3 album
    Code:
    <item id="d-3823152705534391619-co2AF99E5C6CA8302A" parentID="co2AF99E5C6CA8302A" restricted="0"><dc:title>07 Hi Kids</dc:title><res duration="0:03:13.000"
          protocolInfo="http-get:*:[B]audio/mpeg[/B]:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=03700000000000000000000000000000">http://192.168.178.41:26130/content/c2/b16/f44100/d-3823152705534391619-co2AF99E5C6CA8302A.mp3</res><res duration="0:03:13.000"
          protocolInfo="http-get:*:[B]audio/wav[/B]:DLNA.ORG_PN=WAV;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=03700000000000000000000000000000">http://192.168.178.41:26130/content/c2/b16/f44100/d-3823152705534391619-co2AF99E5C6CA8302A.forced.wav</res><res duration="0:03:13.000"
          protocolInfo="http-get:*:[B]audio/L16[/B]:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_CI=1">http://192.168.178.41:26130/content/c2/b16/f44100/d-3823152705534391619-co2AF99E5C6CA8302A.forced.l16</res><res duration="0:03:13.000"
          protocolInfo="http-get:*:[B]audio/mpeg[/B]:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=03700000000000000000000000000000">http://192.168.178.41:26130/content/c2/b16/f44100/d-3823152705534391619-co2AF99E5C6CA8302A.mp3</res><upnp:class>object.item.audioItem.musicTrack</upnp:class></item>
    2.) ForceToMP3 works
    Code:
    =FSL
    [ForceAlbumArt=480]
    [ForceToMP3]
    .mp3
    [ForceToSINGLE]
    .flac
    .m4a
    a.) Selection of a MP3 album
    Code:
          protocolInfo="http-get:*:[B]audio/mpeg[/B]:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=03700000000000000000000000000000">http://192.168.178.41:26130/content/c2/b16/f44100/d544576185538479099-co4B5237296F65FF9E.forced.mp3</res><upnp:class>object.item.audioItem.musicTrack</upnp:class></item>
    - Christian
    • 1645
    Re: ForceToSingle in Control Point Overrides does not work
    Bug confirmed and fixed for the next update, thanks for reporting.
    • asset-user
      • Nov 2018
      • 21
      I can confirm that the bug is fixed in R6.2-beta13. Thanks!
      • asset-user
        • Nov 2018
        • 21
        ... for the first listed format, but not for the successors.
        In this configuration, is works for FLAC, but not for M4A:
        Code:
        [ForceToSINGLE]
        .flac
        .m4a
        In this configuration, is works for M4A, but not for FLAC:
        Code:
        [ForceToSINGLE]
        .m4a
        .flac
          • 1645
          Thanks for testing the fix.
          You are supposed to enter a semicolon-delimited list of file formats - not one format per line.
          Example:
          Code:
          [ForceToSINGLE]
          .m4a;.flac
          • asset-user
            • Nov 2018
            • 21
            Thanks, I'll try that.
            I suggest to fix the docs then.
            • asset-user
              • Nov 2018
              • 21
              Thanks for the hint, it works perfectly with this syntax.
              Thanks again for fixing the documentation on this topic as requested by me; please take care of the OS X manual that also contains the old syntax.
