Newbie needs help with dynamic browsing
  • dkaplin
    • Oct 2018
    Hi
    I'm just starting to use Asset and can't figure out the first step to firing up Dynamic Browsing or setting up personal playlist type things. Could I get a hint or some directions from the forum please?
    I am using:
    QNAP TS-251+ with NAIM and am using the NAIM app as the control point.
    Also, Bliss to clean up the album art.
    Where do I start?
    • 46231
    Re: Newbie needs help with dynamic browsing
    Dynamic browsing has no setup, you browse it through Dynamic Browsing in the control point.
    • dkaplin
      • Oct 2018
      <facepalm> thanks - I just needed to play with it I guess!
      • timster67
        • May 2014
        • 210
        FYI you can also set bookmarks to a particular dynamic browsing choice (if that's what you mean by "personal playlist type thing"). They will appear at the top level and is a convenient (ish) way to create playlists on the fly. I have one set up like this for generating a random playlist from a set of exclusion criteria but it could be anything as long as the path is valid:
        "Exclusions for Random Playlists**Additional&+&Dynamic Browsing&+& [Exclude]&+&Genre&+&Rap&+& [Exclude]&+&Genre&+&Musical&+& [Exclude]&+&Genre&+&Instrumental&+& [Exclude]&+&Genre&+&Punk"
