Asset UPnP not showing up on LG Smart TV
  • Belfaborac
    • Jun 2018
    Basically as the heading states: Asset is not showing up in the TV's list of sources. My main DLNA server is Serviio, which shows up fine and has never presented a problem on this or any previous DLNA-capable TVs.
    The service is running (and set to Automatic: Delayed Start), the running mode is set to Local Account (it doesn't show up when set to Service either) and apart from that I can't see what else I can change to try to make things work.
    Both Asset and Serviio is running on my main (and only) computer, which has a cabled connection to my broadband router and to which the TV is also connected by cable.
    Any ideas?
    • 46230
    Re: Asset UPnP not showing up on LG Smart TV
    Does Asset how up on any other devices? (such as a control point on and ipad).
    • Belfaborac
      • Jun 2018
      Pardon the delay. I pulled a muscle in my back and the question disappeared beneath exquisite agony... :D
      Anyway: nope, it doesn't show up anywhere else I've checked, which includes only a couple of DLNA apps on my phone.
        • 46230
        It is likely you have security software blocking asset from accessing the network, such as firewall.
        • Belfaborac
          • Jun 2018
          Hmmm. The only security software I have is Windows Defender Security Centre (on Windows 10 Pro) and the Windows Firewall is set to let it through.
            • 46230
            Has Asset ever worked for you? or is a new setup?
            • Belfaborac
              • Jun 2018
              It has worked in the past, but to be honest I'm not entirely sure when or on what configuration. This is a recently built PC and the first install of Asset on it.
                • 46230
                Open Windows explorer (on the same computer asset runs on), and click network
                under 'media devices' does asset show?
                • Belfaborac
                  • Jun 2018
                  That's another no. In fact, in Explorer under Network there are no media devices, just the broadband router under Network Infrastructure.
                    • 46230
                    Try uninstalling Asset, then a full restart of the computer and reinstall Asset.
                    • Belfaborac
                      • Jun 2018
                      Well what do you know, that did the trick. I already tried a un/reinstall, without a result, but now everything appears to do exactly what it says on the tin.
                      Thank you for sorting me out, it's very much appreciated!
                      • Jorden Lie
                        • Jul 2020
                        likely you have security software blocking assets from accessing the network, such as a firewall.
                        • Newton John
                          • Dec 2015
                          • 33
                          Hi
                          I've got a similar problem - Asset does not show up in Linn Kazoo since I've reinstalled Windows 10 even though it appears to be working ok and appears in File Explorer.
                          I have tried switching off the firewall and anti virus software. Any suggessions to cure this will be much appreciated.
                          Edit: Curiously it does appear in Kazoo when run on my Windows 10 laptop so I can use it. However, it still doesn't appear on the Windows 10 NUC that is running Asset.
