Raspberry fstab setting for mounting drive
  • ASF
    • Jun 2012
    • 123
    Re: Raspberry fstab setting for mounting drive
    I am using NFS, so I assume this will not apply?
    • PSH
      • Mar 2015
      • 39
      I used to have a working system based on an earlier version of Asset but since upgrading my Raspberry Pi and moving to Asset 6.1 I haven't managed back to a working system.
      It is all based on the failure of the share commands in fstab.
      I have tried all the suggestions in this thread and the only one that works is the manual mount command. As someone else has said, this means a remount and rescan ever time the Pi goes down for whatever reason.
      There must be a better way. Any other suggestions greatly welcomed.
      .............otherwise I might have to dig my CDs out of storage!
      • psweetie
        • Feb 2016
        • 76
        things changed with newer versions of Raspian and seemed to change again v recently as it was not working, I resolved the issue and then it broke again. This is what I use for cifs (SMB) connection:
        //xxx.xxx.xxx.xxx/media /home/pi/nas cifs nofail,username=admin,password=yourpassword,vers=3 .0,x-systemd.automount and it is working away now
        Philip
        • PSH
          • Mar 2015
          • 39
          Many thanks for that suggestion.
          Before I implement it can I just ask whether I should also be activating SMB version 3 on my Synology NAS. As it stands the NAS uses the range SMB1 to SMB2 and Large MTU.
          • PSH
            • Mar 2015
            • 39
            I just went ahead and activated the SMB version 3 on my NAS.
            I then implemented your suggested syntax referring to vers=3.0 in fstab, rebooted and hey presto! It's up and running again.
            Thank you very much indeed Philip (psweetie).
            • psweetie
              • Feb 2016
              • 76
              #21
              :-) shame it is a moving target but hopefully will solve for a bit!
              • PSH
                • Mar 2015
                • 39
                #22
                I was too hasty!
                In fact it only mounted one of my libraries and when I rebooted to see whether it might mount both libraries nothing mounted.
                Looks as though I'll have to go back to manual mounting.
                • PSH
                  • Mar 2015
                  • 39
                  #23
                  The treasure trove that is the world-wide web has at last got me sorted.
                  Just in case anyone else suffers the complete meltdown of their networked music system like I did, I should at least put on record the means by which I got it up and running again.
                  I used the information outlined in the June 2018 post from Jacques Gerber - thanks Jacques!
                  You can find the info here:https://raspberrypi.stackexchange.com/a/84757
                  • psweetie
                    • Feb 2016
                    • 76
                    #24
                    I would still try it with vers=3.0 and SMB 1 is slower than newer versions as I understand it. Agree with setting the "wait for network on boot" option within the boot section of raspi-config. I do have that set.
                    Philip
                    • PSH
                      • Mar 2015
                      • 39
                      #25
                      Good suggestion - I'll try that Philip.
                      Silence means it will have worked...........otherwise I'll be back..........and hopefully not worse than before!
