Song Images Not Displayed for Playlists Created using Playlist Creator
  • Gavin Blackett
    • Jan 2014
    • 25
    I use Playlist Creator to generate m3u playlist files. I can play the playlists using the Naim App, but no song images are displayed. Images are fine elsewhere - Album Artist, JUkebox Track Selection, Playlists created by Naim App, but not these 'external' ones.
    Anything I can check?
    Asset is r6 running on a QNAP HS-251+ NAS.
    Gavin
    • 46231
    Re: Song Images Not Displayed for Playlists Created using Playlist Creator
    You would have to add the location of these tracks to be indexed by asset for the art to be presented when browsing the playlist.
    • Gavin Blackett
      • Jan 2014
      • 25
      Hi Spoon
      I think they are, as part of the main collection location.
      In my set up I have asset pointing at /share/Multimedia/Music with /album artist / album after that.
      The playlists location points to /share/Multimedia/Music/Playlists, and all the playlists have relative paths pointing back to the files such as ../Abba/Gold/filename.flac
      Is there something else to specify for playlists?
      Gavin
        • 46231
        Playlists would have to have the full path, not a relative path to be mapped back to art.
        • timster67
          • May 2014
          • 210
          Unfortunately that's not possible with Playlist Creator. You would have to edit the m3us manually and replace the "../" with "/share/...etc".
          Shame Asset can't map back itself, as I have also discovered all playlist tracks playback at 44.1 when passed through the transcoder regardless of actual resolution of the track.
          Minimserver manages to do both with relative paths.
          • Gavin Blackett
            • Jan 2014
            • 25
            Thanks everyone, that&*8217;s solved my problem. I&*8217;ve has to manually edit the file as suggested but that&*8217;s not a problem.
