Help with Asset uPnP search function
  • Chris2465
    • Mar 2018
    • 11
    The search function (spyglass icon) in Asset nPnP does not work: whatever term (even if the search word is random letters), the returned result is the same.. Is this a common problem?
    I use a Linn streamer, store my music on a QNAP NAS.
    To stream music, I use Kazoo on any of my devices: MacBook/iPhone/Windows desktop... the search function, regardless of the device, performs identically.
    Is any help available on this question?
    Re: Help with Asset uPnP search function
    What search function (spyglass icon) in Asset nPnP? Aren't you referring to the search facility in your client software?
    If I recall, the DLNA/UPnP specification is very limited when searching e.g. it is limited to artist, album and title only.
    • Chris2465
      • Mar 2018
      • 11
      Thanks for the response. I think you're right: I should not refer to the search function in Asset uPnP. Rather, I'm referring to the search function in Kazoo. However, if I've selected Asset as my media server software (which is my preference), then the Kazoo search function does not work. If I select another media server software (eg. Twonkey), then the Kazoo search function works well. So - perhaps erroneously - I've deduced that Asset is the problem.
      • timster67
        • May 2014
        • 210
        What version of Kazoo are you using? I have Kazoo on Windows 7, 10 and iOS. Asset on QNAP. The search works as expected.
        • Chris2465
          • Mar 2018
          • 11
          Thanks for responding. I think I have solved the question: I erased Asset on QNAP, and re-installed. And I seem to have a fully functioning search capability. Problem solved!
          C
