Using Asset as an A/D converter ?
  • madbrain
    • Sep 2017
    This doesn't appear possible currently. I see there is a sound card streaming option on PC in the premium version, but it appears to stream the soundcard output.
    What I'm looking to do is stream the soundcard input, ie. to record an analog audio device and present it as a DLNA server.
    Is this possible with the premium version ? Or can it be considered in the future ? I would be using it with a Raspberry Pi or ODROID XU4 and a USB A/D converter (probably 24/96).
    Thanks !
    • 46231
    Re: Using Asset as an A/D converter ?
    Asset is the server not player, you would need a upnp compatible player.
