uMediaLibrary-dumpdb.exe output, multi-value tags are not consistent
    In uMediaLibrary-dumpdb.exe, t_artist is output with the semi-colon character as the separator, if it contains multi-values. However, t_artist iID is output with the linefeed and/or carriage return character as the separator, if it contains multi-values.
    Please can this behaviour be changed so that all multi-value tags are output consistently, i.e with semi-colons. Currently, this makes importing into spreadsheets etc. a real pain.
    • 46230
    Re: uMediaLibrary-dumpdb.exe output, multi-value tags are not consistent
    These two read the same to me, what is the difference?
      (examples copied and pasted directly from uMediaLibrary-dumpdb.txt)
      t_artist:
      Cluster and Eno [1928]; Cluster [1921]; Brian Eno [300]
      so, t_artist is separated with semi-colon and space [; ]
      However, t_artist iID is separated by an unknown character. Excel (and this forum editor, when I paste here) treat the unknown separator character as a linefeed and/or carriage return character.
      t_artist iID:
      1929 Cluster and Eno
      Cluster
      Brian Eno
      I would like t_artist iID to have the same [; ] separator in the output text file, so:
      Cluster
      Brian Eno
      becomes:
      1929 Cluster and Eno; Cluster; Brian Eno
        More info.
        The output text file tables, affected by the issue described are:
        t_artist iID
        t_album iID
        t_conductor iID
          • 46230
          Strange, t_artist iID should only have a single artist. I am not sure how you have multi artists in there.
            The issue is the same for all t_artist iID, where t_artist is a multi-value tag.
              • 46230
              Try a rescan all, what format are your audio tracks?
                Rescan All makes no difference. Audio library is flac and mp3 (ID3v2.3).
                ... I removed the mp3's from Asset, so I only have flacs and the issue still exists.
                Last edited by mville; September 11, 2017, 02:17 PM. Reason: changed Asset to flac only
                  More info.
                  t_artist iID
                  t_album iID
                  t_conductor iID
                  t_conductor iID is now not an issue, as I had a handful of tracks with 2 conductors, however it seems dBpoweramp and Asset do not support multi-value conductor tags for the flac file format.
                    • 46230
                    This is correct, conductor is a singular item. All the tagging standards specify conductor as a singular item.
                      Yes, I believe I confirmed that in post no. 9.
                        I notice that the new Asset R6.1 has not fixed the issue with the uMediaLibrary-dumpdb.exe output and the t_artist iID and t_album iID tables.
                        Is this something that will be fixed in the future?
                          In addition to the bug reported here in Asset R6.1 beta for Mac/Linux:
                          I thought I would add the following screenshot of the t_artist table in Asset R6.1 for windows, which shows a problem for storedvalue and sortvalue in Row 4 and, explains why I was having a problem with the uMediaLibrary-dumpdb.exe output:
