PC Sound Capture Streaming
  • map856
    • May 2012
    • 25
    I've just started looking into using PC sound capture streaming. My attempts so far seem to always result in an mp3 stream, max 320kbs, regardless of file type being played on the PC. Is this as expected or is there some way to stream in a lossless mode?
    Many thanks.
    • 46231
    Re: PC Sound Capture Streaming
    On the advanced configuration page you set the file type .WASAPI to Wave
    • map856
      • May 2012
      • 25
      Thank you Spoon - worked a treat. Apologies for the late response.
