Asset UPnP R2026-08-19 problem.
  • Mike-B
    • Aug 2018
    • 223
    Asset UPnP R2026-08-19 is refused as a download by BT Cyber Threat Protect.
    This is the same problem as with the previous R2026-07-29 ..... a Bot threat called ELF: Specter-C
    I don't doubt the file is safe as per Spoon post on R2026-07-29 thread
    and have downloaded the file, and it works perfectly, but only by completely uninstalling the BT security package "BT Cyber Threat Protect"
    But this is the standard security package included with all BT Broadband contracts and as BT is the UK's leading BB provider with aprx 25% market share this problem can't just be discounted as a BT problem.
    Is there anyway you can clean this trace/ghost problem from the file ???
    • 46228
    which platform again?
    • Mike-B
      • Aug 2018
      • 223
      Synology DS214 DSM 7.1.1.(update 9) with Linux-ARM32
      • RayK
        • Jul 2026
        • 9
        R2026-08-19 Installed and running fine on Synology DS214play. No virus alerts with Bitdefender. Thank you again
