Radio Stream Problems (Asset UPnP Docker)
  • Matthias
    • Feb 2026
    Hello, I am currently evaluating Asset UPnP using this docker image: https://hub.docker.com/r/ckware/asset-upnp
    After installing curl inside the container, the streams worked at least with BubbleUPnP.
    VLC no longer throws any error messages, but there is still no audio.
    Two questions: is the image being used actually the correct one, and are there any known issues with radio streams when using VLC?
    • 46189
    You could try setting the radio stream as mp3 on the config page.
    (extension would be .RADIO)
    • Matthias
      • Feb 2026
      That was indeed the problem — LPCM was set there. I had tried a few settings because there were issues (which were actually caused by the missing curl) and forgot to change that setting back.
      I’ve now set RADIO back to “as is,” and it’s working.
