Asset 5.1 problem with playying certain files
  • stickymelon
    • Feb 2015
    • 8
    I have a problem with playing certain files thorugh my CA Stream Magic on Asset 5.1 (i dont recall havin the same issue with Asset 4+). Even within the same album, all ripped at one go, one track plays ok, other - "stalls" on my streamer.
    I'm struggling to find some pattern. Looks like an issue with short files (<1min) (mp3's, m4a's) although I've also got problems with certain albums (mp3)... If i use the same library using different media server, files works perfectly fine.
    During my research i discovered, that removing album art helps a bit - the playback starts, but after 20+ seconds instead of instantly.
    Im more than happy to help and provide all the required info info.
    Re: Asset 5.1 problem with playying certain files
    Try setting Asset to decode the files 'as wav' to see if helps.
    • stickymelon
      • Feb 2015
      • 8
      i've got some hi-res files 24/96 in m4a so decoding to wav isn't an option. I made an experiment and set decoding to wav. It makes, that playback skips first 1-2s at file startup...
      Detting decoding to wav helped with stalling 'streamer', but makes something weird with some tracks - difficult to decribe, but parts of tracks repeat itself (as if there was some kind of retransmission in the network added to stream) - results in more or less scratched record syndrome... Same track without decoding plays ok. I coult try to record the outcome, if it would be any help.
      All and all not much luck with decoding to wave...
      • stickymelon
        • Feb 2015
        • 8
        Further analysis of "decode as" anomaly shows signs of skipping instead of previously stated repeaitng segments of track. It looks like it is skipping ~1s segments of the track, without disturbing the track timer. It occurred on every decoding to option (decode to wav, pcm, even to mp3) - disabling decoding solves the problem.
        Short track playback problem still occurs.
          I do not know what more to suggest, sorry.
          • stickymelon
            • Feb 2015
            • 8
            Yep, thakns for all the help - if I fugure out what is going on I'll post the solution.
            • stickymelon
              • Feb 2015
              • 8
              Reverting to Asset 4.1 resolved all playback problems (decoding issue still present). I'll stick to 4.1 for now...
