4.6.3 on OS X (10.11.3) problems with folders and crashes
  • tnk
    • Feb 2016
    Hi there,
    I've updated to the new version 4.6.3 and since doing have a couple of problems (possibly related).
    I've a folder for playlists and a separate folder for my music (in a common root). The GUI allows me to set these correctly, however on applying and reopening the configuration page the folders both revert to that where the music is. On adding the playlist folder and deleting the incorrect playlist folder, this results in Asset UPnP crashing.
    I've tried deleting and reinstalling with the same result.
    Appreciate any assistance.
    Ta
    Tom
    • 1656
    Re: 4.6.3 on OS X (10.11.3) problems with folders and crashes
    Thanks for your feedback, problem is being looked into.
      • 1656
      New beta posted-
      Relevant bug should be fixed.
