Adding custom tags
  • jwr31
    • Jan 2016
    • 13
    Re: Adding custom tags
    Ok,
    I re-booted my laptop, "Refreshed all" and ran the uMediaLibrary-dumpdb.exe.
    When I looked at the dump file the column exists but not data is being pulled. The column is empty. If you like I could send you the dump file and the MediaDatabaaseFieldsv5 file if that would help.
      • 44076
      It is likely that dBpoweramp is reading the tag as a different value, if you right click on a file >> Edit ID tags this will show how dBpoweramp reads the tag.
        • 4015
        jwr31 has confirmed in post no. 12 (in response to post no. 11), that the tag is Grouping, with the correct data, when viewed in Edit ID-Tag.
        ... jwr31, can you confirm this again please, perhaps with a screenshot?
        • jwr31
          • Jan 2016
          • 13
          Here is are some screen shots
Name:	ID Tag Screen Shot.jpg
Name:	AssetDump Screen Shot.jpg
            • 4015
            [ATTACH=CONFIG]862[/ATTACH]
            [ATTACH=CONFIG]863[/ATTACH]
            These aren't dBpoweramp Edit ID-Tag screenshots. Do you have dBpoweramp Music Converter installed?
            ... further digging around and I have discovered that the Audioshell Grouping tag uses the conventions used by Tag&Rename.
            The tag names used by different softwares is not standardized. I think the Tag&Rename/Audioshell Grouping tag is called Style in dBpoweramp/Asset and this tag is already predefined in the MediaDatabaseFieldsv5.txt, so you don't need to add it.
            If I am right, all you need to do is Launch Asset UPnP Configuration >> Advanced Settings >> Browse Tree
            and select the Style node/container from the dropdown list.
            Last edited by mville; February 04, 2016, 02:57 AM. Reason: audioshell/Tag&Rename discovery
            • jwr31
              • Jan 2016
              • 13
              #21
              You nailed it! I have been using iTunes to rip the CDs and was just using Audioshell to view the tags.
              I now see my music collection as I wanted using the Styles container. Thanks guys.
              There is one more thing I want to learn to do but am having difficulty finding information on how to do it. Basically, if I wanted to build some logic into a container how could I do that? (i.e. a container that allows me to see items with a Styles tag value of either 4 or 5). Can you point me in the right direction?
              Thanks again.
                • 44076
                #22
                You can use the Dynamic browsing, with including items.
                • PepsiCan
                  • Apr 2014
                  • 106
                  #23
                  How do we do this on unix based machines like QNAPs and Raspberry Pis?
                    • 44076
                    #24
                    Through a ssh connection, it is not easy as requires knowledge of Linux to browse to the configuration files and edit them.
                    • PepsiCan
                      • Apr 2014
                      • 106
                      #25
                      Can we have the file names and locations? I don't need a full tutorial but some pointers would be nice. For me, being able to add custom tags like in MinimServer is make or break. Running Asset on a windows box is not an option as I'd need a new machine.
                        • 44076
                        #26
                        For the qnap:
                        The location of Assets configuration files are: /share/MD0_DATA/.qpkg/Asset/bin/.dBpoweramp/
                        for the Pi:
                        The configuration files for Asset are stored: ~/.dBpoweramp
                        • PepsiCan
                          • Apr 2014
                          • 106
                          #27
                          For the qnap:
                          for the Pi:
                          I found the file MediaDatabaseFieldsv4.txt. Thank you for that.
                          I added my custom tag (ORIGINALDATE) to the file at the bottom as originaldate,0,INTEGER. I saved the file, checked that the entry is there through CAT and then restarted AssetUPnP. When I want to edit the browse tree, I don't see the new field. Did I miss a link somewhere? Is my capitalisation not correct? What am I missing?
                            • 44076
                            #28
                            You have to manually type this new value into the tree.
                            • PepsiCan
                              • Apr 2014
                              • 106
                              #29
                              Do you mean the tree in the webbrowser? I was expecting the drop-down list there to show the new value in the list. But I'll try typing it in later this evening. Thanks!
                              • PepsiCan
                                • Apr 2014
                                • 106
                                #30
                                I must be missing something very obvious. I edited the file MediaDatabaseFieldsv4.txt and at the bottom of the list I added
                                Code:
                                The field gets a YYYY MM DD or YYYY MM or YYYY value.
                                I then proceed to edit the AssetUPnPDefinedBrowseTreev4.txt file as follows:
                                Code:
                                Artist / Album{_a_to_z_}{_no_track_list_}
                                Artist / Album\Album
                                Album{_a_to_z_}
                                Title{_a_to_z_}
                                OriginalDate{_no_track_list_}
                                originaldate{_no_track_list_}
                                Composer{_a_to_z_}{_no_track_list_}
                                Composer\Album
                                I wasn't sure whether casing makes a difference. If it does, then OriginalDate is the tag that should be used.
                                Anyway, what am I missing*? A file? A location? Thanks for the help!
