Asset Upnp 2024-12-16 Problem:Library is zero at every PC power on-off-on time
  • HARTLEY220
    • Jan 2025
    asset upnp 2024-12-16 Problem: After installing and starting operation, the library becomes "0" every time the PC is turned off and on. It is still unusable.
    • 46231
    What is asset running on?
    • jet70
      • Jan 2025
      I have similar issues on a Synology DS216SE but the Asset Install will not allow me to uninstall, Is there any guidance as to how to manually totally remove the December release from my Synology NAS? Thank you
        • 46231
        This is being investigated on the specific threads dealing with synology.
        this thread is about the windows version.
        • HARTLEY220
          • Jan 2025
          I'm using on Windows10.
            • 46231
            Which security software do you have? and how is Asset running? local account or service?
            • HARTLEY220
              • Jan 2025
              I have been using ESET INTERNET SECURITY security software for many years. I have been using Asset with a local account. I have never had any problems with this setting.
                • 46231
                Open Windows Explorer and in the address bar type:
                %appdata%\dBpoweramp\uMediaLibrary-r8
                Run asset, you will find files are created in that folder. On a restart look in that folder, it is not Asset which is deleting the files.
                • HARTLEY220
                  • Jan 2025
                  Thank you for your advice.
                  I'm not sure how to judge it based on your instructions.
                  Strangely enough, there are no issues today.
                  I've been using it for a few years now, but this latest version is noticeably unstable.
                  • sonci
                    • Jul 2024
                    • 11
                    It just turns itself from Local account to service for no reason at all. I always leave it as recommended. Just configure it as Local account and library is back.
                    But 2023 version is much better.
