Asset Control Point?
  • RichP
    • Nov 2020
    Hi. Just installed Asset UPnP after using Kazoo Server for many years. Is there an Asset control point for Windows or Android? Apologies if it's on the website and I didn't spot it.
    Many thanks
  • simbun
    • Apr 2021
    • 263
    BubbleUPnP is the best UPnP control point, especially when coupled with BubbleUPnP Server which adds additional functionality (the ability to control multiple renderers and access queues from different devices).
    For Windows there is a discontinued Asset control product (google 'asset control dbpoweramp'), but I use upplay on the desktop. The UI is a little basic but it's very functional and the dev is very responsive. Unfortunately it's not free for Windows.
    • IdrisRoberts
      • Feb 2018
      • 26
      There is BubbleUpnp on Android. jplay on IOS and Mconnect which can be used on both platforms. Each has its good and not so good points. All 3 have either free or try before you buy apps.
      personally I prefer Jplay.
      • Wayne
        • Aug 2002
        • 1254
        I use Foobar on my android phone to play audio files on my phone or from Asset on my Qnap NAS.
