Asset for QNAP doesn't work
  • Klaus
    • Sep 2015
    Good Morning to eveybody,
    hope You can help me with my problem.
    I just bought a QNAP HS-251 which is running on latest (as indicated after clicking the upgrade button) firmware 4.1.4 and although bought and installed Asset for QNAP. So far so good - the Asset Icon is shown on QNAP.
    I tried to scan my music library which is also on the QNAP HS-251 but it does't work.
    It just shows me 'Restarting Asset' and 'Rescanning ...' without any result in the main Asset menue - especially it shows (0 Albums) and (0 Tracks).
    Furtheron I cannot access my music files from my Networkplayer (MOON MiND) respectively my Digital Analog Converter.
    Maybe I have a wrong spelling of the path I had to insert in the configuration screen.
    Can anybody help me?
    Thanks a lot and have a fine day
    Klaus
    • 46231
    Re: Asset for QNAP doesn't work
    Normally you would not change the path, and the path you enter is not the external network share path, instead it is the internal path on the system. Where is you music saved? what path have you entered?
    • Klaus
      • Sep 2015
      Thanks for reply
      The path is ' /Multimedia/music/AIFF_RIP' where the dbpoweramp files in AIFF-Format are located.
      Both (data and Asset UPnP App) are on the NAS (QNAP HS-251).
      Asset App seems to know that because it states themselve as to be on the NAS with the NAS-Name in the network.
      Help-Page says that path has to be entered, starting with "/". Nevertheless I tried multiple spellings which all didn't work.
        • 46231
        It is more likely to be:
        /share/Multimedia/music/AIFF_RIP
        • Klaus
          • Sep 2015
          Hello Spoon,
          that's it - now it works and albums and tracks are shown in the Counter!
          Thanks a lot for your help and have a good day!
          Klaus
