Problems with AssetUPNP Mac and Astell Kern Player
  • Lohengrin123
    • Dec 2012
    • 9
    Hi ,
    I use Asset Upnp on my Mac since the beginning with no problems to stream my music from my Mac mini to a T+A streaming player. Now I want to stream the music also to a Astell Kern Musicplayer (AK240). After some seconds the music stops. If I use the server software (which I hate...) from iRiver I have no problems..
    Any ideas what to change in Asset UPNP?
    Thanks for your help!
    Michael
    • 46231
    Re: Problems with AssetUPNP Mac and Astell Kern Player
    Is the player wired or wireless?
    • Lohengrin123
      • Dec 2012
      • 9
      The player is wireless. It is a aluminum body and I would think this is the problem. But why does it work with other server software and why don't have other user this problems? Maybe there is any possibility to get this work with Asset..
      Thanks..
        • 46231
        What file type are you playing?
        When the audio stops what happens, it resumes later, or moves to the next track?
        • Lohengrin123
          • Dec 2012
          • 9
          [QUOTE=Spoon;159381]What file type are you playing?
          Mostly AIFF but it happens also with mp3. The playback just stops and nothing more happens. If I try to play another song, it starts playing and stops after about three seconds.
            • 46231
            Perhaps ask Astell for their input on this issue.
            A UPnP server supplies files like a web page, they are sent as is and using http, if there was an issue with Asset it would affect all players.
            • Lohengrin123
              • Dec 2012
              • 9
              [QUOTE=Spoon;159390]Perhaps ask Astell for their input on this issue.
              Thank you very much.. I'll try to contact them..
              Michael
