Help with straming to oppo bdp-105
  • petertg
    • May 2015
    I am trying to stream aiff, flac and wav files to an oppo bdp-105. The files play for a few seconds then skip to the next track or no sound comes out at all. How can I fix this?
    • 46233
    Re: Help with straming to oppo bdp-105
    Does any file type (such as mp3) play?
    • petertg
      • May 2015
      This happens with all file types. I posted on the oppo site and was advised to try another music server. Of course they blamed it on the asset server software mentioning something about timeouts. I am now using minimserver which works fine but I wanted to use asset server since I paid for it and it has more features. BTW I am running it on an imac.
        • 1658
        Thanks for your feedback.
        Potential solution to the problem:
        Open Asset configuration, under "Audio Format Streaming", try different streaming options for the formats you're streaming; perhaps at least one (such as LPCM) will work with your unit.
        If the above fails, there's a couple of things we'd like to know in order to troubleshoot this:
        • Any other software (control point, iPad app or alike) used to control playback?
        • Asset UPnP version? Please make sure you're on the latest & greatest R4.5 on the mac
        • Security / antivirus software installed on the mac potentially blocking Asset from working?
        • Can you try Asset UPnP on another machine (can be Windows or Linux trial version) to see if it works?
