Stream pc audio to Sony SA-NS510 DLNA speaker
  • Mr Tickle
    • May 2015
    Hi - just purchased Asset uPnP Professional and I was hoping that I could stream the PC audio to my DLNA speaker but I cannot fathom out where to start.
    Basically I want to stream music in the same way Windows Media Player does using the Play To feature (which does work)
    Any help appreciated
    thanks
    Simon
    Re: Stream pc audio to Sony SA-NS510 DLNA speaker
    Look for the Asset UPnP Help. It is a shortcut installed on your PC (assuming you have a Windows PC). Next, having read the Advanced Settings section of the Help, you have to configure Asset using Asset UPnP Configuration.
    • Mr Tickle
      • May 2015
      hi - been through the help but it doesnt detail how capture the sound stream it to my speaker.
        • 46233
        You browse to:
        Advanced Search >> PC Sound card capture [wasapi]
        and add that entry to the playlist then play it.
        • Mr Tickle
          • May 2015
          hi - the implication is there is an entry under WASAPI but I don't have any.
          Is that correct?
            • 46233
            Which Windows version do you have?
            • Mr Tickle
              • May 2015
              windows 7
