QNAP TS-470 Pro and Asset UPnP
  • Chip
    • Aug 2008
    • 102
    It is time to replace my NAS and I want my new NAS to run Asset natively.
    I am considering the QNAP TS-470 Pro with an Intel® Core™ i3-3220 3.3 GHz Dual-core Processor.
    Before making this purchase I would like to confirm that Asset will run on this NAS.
    Will the QNAP Release 4.4 Intel (n51, n69, n69L, n70, n53pro, HS-251 where 'n' is 1, 2, 4, etc) also run on the Pro version?
    • 45336
    Re: QNAP TS-470 Pro and Asset UPnP
    Yes it will.
      Super Moderator
      • 1559
      All ARM models and Intel Core models are supported.
      The only models we do not currently support are Intel Atom 32-bit models - 259/459/659/859 and the new 269h - reason being that they're all either very expensive or hard to find, usually both. Intel Atom based models running 64-bit Linux are supported (269/469/... series).
