ASSET Premium Playlist problem.
  • JEM2
    • Dec 2013
    • 20
    Hi.
    I have ASSET Premium running successfully on my QNAP TS 412 and NAIM Unitilite except for the Playlist function.
    The problem is on manually selecting any number of tracks for a playlist and then naming the playlist it automatically fills with unwanted tracks until full with 500 tracks.
    If I play a playlist from the present menu it also fills with 500 tracks.
    It is not possible to have a playlist with anything less than 500 tracks.
    This behaviour occurs with both a Android or Apple device interface.
    The standard ASSET version playlist function worked without fault.
    I ran until recently a Raspberry Pi version of ASSET premium and it suffered the exact same problem with playlists.
    The Playlist function is a key feature of a server based music system.
    I suspect there is a bug in ASSET premium or am I doing something wrong.
    Any suggestions please.
    Thanks John.
    • 46231
    Re: ASSET Premium Playlist problem.
    Tell me more how you create these playlists, you are using the naim app? you browse to an artist and click add to playlist? and it adds 500 items?
    • JEM2
      • Dec 2013
      • 20
      Hi.
      Yes I am using the NAIM app on both my iPad2 and Samsung 2.
      The problem I had with playlists filling I cannot now reproduce which is good news but a bit embarrassing. I have created 2 playlists both of which have remained stable so I will assume I was doing something through the app to fill the playlists.
      Am I correct to understand the pre programmed playlists like Jukebox etc. randomly generate a selection of 500 tracks from the inventory of tracks?
      Thanks for the support. I'm very please how well ASSET is working on my QNAP.
        • 46231
        Yes these pre programmed lists have 500 items.
