Problem running/configuring Premium Registered Asset version on Debian
  • andreash
    • Dec 2014
    • 10
    Hello,
    I followed exactly the same installation guidelines installing/configuring the 64Bit Premium version of Asset on Debian as I did with the trial version. The trial version ran w/o problem. Trying to configure the Premium version at x.x.x.x:45537 I get the following error message:
    Asset UPnP startup...
    Version: R4.3
    Functionality: Premium Registered
    Supported formats: .wv .ogg .oga .wav .bwf .aif .aiff .aifc .opus .w64 .flac .fla .mp3 .mp2 .m2a .mpga .mpa .mpx .mpg .mp1 .mpeg .m4a .mp4 .m4b .aac .mpc .mpp .mp+
    Starting Asset web interface at http://192.168.23.200:45537
    Detected IP address: 192.168.23.200
    *** glibc detected *** ./AssetUPnP: free(): invalid next size (normal): 0x0000000002683050 ***
    ======= Backtrace: =========
    /lib/x86_64-linux-gnu/libc.so.6(+0x76a16)[0x7f0181d9da16]
    /lib/x86_64-linux-gnu/libc.so.6(cfree+0x6c)[0x7f0181da27bc]
    ./AssetUPnP[0x50dcac]
    ./AssetUPnP[0x5024d0]
    ./AssetUPnP[0x506c04]
    ./AssetUPnP[0x507bd5]
    ./AssetUPnP[0x4dffe0]
    ./AssetUPnP[0x4dfd8c]
    ./AssetUPnP[0x4e9f6c]
    ./AssetUPnP(_ZN15NPT_PosixThread10EntryPointEPv+0x40 )[0x518830]
    /lib/x86_64-linux-gnu/libpthread.so.0(+0x6b50)[0x7f0182846b50]
    /lib/x86_64-linux-gnu/libc.so.6(clone+0x6d)[0x7f0181e037bd]
    ======= Memory map: ========
    00400000-00686000 r-xp 00000000 08:01 918212 /usr/bin/asset/bin/AssetUPnP
    00886000-008a2000 rw-p 00286000 08:01 918212 /usr/bin/asset/bin/AssetUPnP
    008a2000-008a4000 rw-p 00000000 00:00 0
    02676000-02697000 rw-p 00000000 00:00 0 [heap]
    7f017c000000-7f017c021000 rw-p 00000000 00:00 0
    7f017c021000-7f0180000000 ---p 00000000 00:00 0
    7f0180b0f000-7f0180b10000 ---p 00000000 00:00 0
    7f0180b10000-7f0181310000 rw-p 00000000 00:00 0
    7f0181310000-7f0181311000 ---p 00000000 00:00 0
    7f0181311000-7f0181b11000 rw-p 00000000 00:00 0
    7f0181b11000-7f0181b26000 r-xp 00000000 08:01 10486621 /lib/x86_64-linux-gnu/libgcc_s.so.1
    7f0181b26000-7f0181d26000 ---p 00015000 08:01 10486621 /lib/x86_64-linux-gnu/libgcc_s.so.1
    7f0181d26000-7f0181d27000 rw-p 00015000 08:01 10486621 /lib/x86_64-linux-gnu/libgcc_s.so.1
    7f0181d27000-7f0181ea9000 r-xp 00000000 08:01 10486879 /lib/x86_64-linux-gnu/libc-2.13.so
    7f0181ea9000-7f01820a9000 ---p 00182000 08:01 10486879 /lib/x86_64-linux-gnu/libc-2.13.so
    7f01820a9000-7f01820ad000 r--p 00182000 08:01 10486879 /lib/x86_64-linux-gnu/libc-2.13.so
    7f01820ad000-7f01820ae000 rw-p 00186000 08:01 10486879 /lib/x86_64-linux-gnu/libc-2.13.so
    7f01820ae000-7f01820b3000 rw-p 00000000 00:00 0
    7f01820b3000-7f0182134000 r-xp 00000000 08:01 10486883 /lib/x86_64-linux-gnu/libm-2.13.so
    7f0182134000-7f0182333000 ---p 00081000 08:01 10486883 /lib/x86_64-linux-gnu/libm-2.13.so
    7f0182333000-7f0182334000 r--p 00080000 08:01 10486883 /lib/x86_64-linux-gnu/libm-2.13.so
    7f0182334000-7f0182335000 rw-p 00081000 08:01 10486883 /lib/x86_64-linux-gnu/libm-2.13.so
    7f0182335000-7f018241d000 r-xp 00000000 08:01 920479 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
    7f018241d000-7f018261d000 ---p 000e8000 08:01 920479 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
    7f018261d000-7f0182625000 r--p 000e8000 08:01 920479 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
    7f0182625000-7f0182627000 rw-p 000f0000 08:01 920479 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
    7f0182627000-7f018263c000 rw-p 00000000 00:00 0
    7f018263c000-7f018263e000 r-xp 00000000 08:01 10486882 /lib/x86_64-linux-gnu/libdl-2.13.so
    7f018263e000-7f018283e000 ---p 00002000 08:01 10486882 /lib/x86_64-linux-gnu/libdl-2.13.so
    7f018283e000-7f018283f000 r--p 00002000 08:01 10486882 /lib/x86_64-linux-gnu/libdl-2.13.so
    7f018283f000-7f0182840000 rw-p 00003000 08:01 10486882 /lib/x86_64-linux-gnu/libdl-2.13.so
    7f0182840000-7f0182857000 r-xp 00000000 08:01 10486875 /lib/x86_64-linux-gnu/libpthread-2.13.so
    7f0182857000-7f0182a56000 ---p 00017000 08:01 10486875 /lib/x86_64-linux-gnu/libpthread-2.13.so
    7f0182a56000-7f0182a57000 r--p 00016000 08:01 10486875 /lib/x86_64-linux-gnu/libpthread-2.13.so
    7f0182a57000-7f0182a58000 rw-p 00017000 08:01 10486875 /lib/x86_64-linux-gnu/libpthread-2.13.so
    7f0182a58000-7f0182a5c000 rw-p 00000000 00:00 0
    7f0182a5c000-7f0182a7c000 r-xp 00000000 08:01 10486876 /lib/x86_64-linux-gnu/ld-2.13.so
    7f0182c6d000-7f0182c73000 rw-p 00000000 00:00 0
    7f0182c78000-7f0182c7b000 rw-p 00000000 00:00 0
    7f0182c7b000-7f0182c7c000 r--p 0001f000 08:01 10486876 /lib/x86_64-linux-gnu/ld-2.13.so
    7f0182c7c000-7f0182c7d000 rw-p 00020000 08:01 10486876 /lib/x86_64-linux-gnu/ld-2.13.so
    7f0182c7d000-7f0182c7e000 rw-p 00000000 00:00 0
    7fff2978f000-7fff297b0000 rw-p 00000000 00:00 0 [stack]
    7fff297ff000-7fff29800000 r-xp 00000000 00:00 0 [vdso]
    ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
    Restarting Config
    I appreciate any advice to solve this issue,
    Andreas
  • andreash
    • Dec 2014
    • 10
    Re: Problem running/configuring Premium Registered Asset version on Debian
    Update:
    Problem occurs only, if WebGUI is accessed with Firefox, using Safari the page is displayed.
    At least a workaround, problem solved.
    Andreas
      • 1656
      Thank you for the bug report.
      I recommend trying the latest 4.4 beta-
      Changes: Improved scanning performance Added a command in the configuration panel to download entire Asset configuration for debugging Fixed Resource Leak which can cause a lockup Added music folder monitoring for all versions except for QNAP x09 Scanning performance improvements Fixed library not being automatically rescanned
      See if the problem persists.
      I did a quick test run and could not reproduce this issue, on a Debian6 x64 system, in neither Asset version 4.3 nor 4.4 beta, running latest Firefox browser on either OSX or Windows.
      • andreash
        • Dec 2014
        • 10
        The problem still persists. I get the following dump:
        root@OMV-Server:/usr/bin/asset/bin* ./AssetUPnP
        Version: R4.4 beta
        Functionality: Trial 8 Days Remaining
        *** glibc detected *** /usr/bin/asset/bin/AssetUPnP: free(): invalid next size (normal): 0x0000000000e3dbf0 ***
        /lib/x86_64-linux-gnu/libc.so.6(+0x76a16)[0x7f7925b66a16]
        /lib/x86_64-linux-gnu/libc.so.6(cfree+0x6c)[0x7f7925b6b7bc]
        /usr/bin/asset/bin/AssetUPnP[0x51441c]
        /usr/bin/asset/bin/AssetUPnP[0x508c40]
        /usr/bin/asset/bin/AssetUPnP[0x50d374]
        /usr/bin/asset/bin/AssetUPnP[0x50e345]
        /usr/bin/asset/bin/AssetUPnP[0x4e6730]
        /usr/bin/asset/bin/AssetUPnP[0x4e64dc]
        /usr/bin/asset/bin/AssetUPnP[0x4f06bc]
        /usr/bin/asset/bin/AssetUPnP(_ZN15NPT_PosixThread10EntryPointEPv+0x40 )[0x51efa0]
        /lib/x86_64-linux-gnu/libpthread.so.0(+0x6b50)[0x7f792660fb50]
        /lib/x86_64-linux-gnu/libc.so.6(clone+0x6d)[0x7f7925bcc7bd]
        00400000-00690000 r-xp 00000000 08:01 1049887 /usr/bin/asset/bin/AssetUPnP
        00890000-008ac000 rw-p 00290000 08:01 1049887 /usr/bin/asset/bin/AssetUPnP
        008ac000-008ae000 rw-p 00000000 00:00 0
        00e35000-00e56000 rw-p 00000000 00:00 0 [heap]
        7f7920000000-7f7920021000 rw-p 00000000 00:00 0
        7f7920021000-7f7924000000 ---p 00000000 00:00 0
        7f79248d8000-7f79248d9000 ---p 00000000 00:00 0
        7f79248d9000-7f79250d9000 rw-p 00000000 00:00 0
        7f79250d9000-7f79250da000 ---p 00000000 00:00 0
        7f79250da000-7f79258da000 rw-p 00000000 00:00 0
        7f79258da000-7f79258ef000 r-xp 00000000 08:01 10486621 /lib/x86_64-linux-gnu/libgcc_s.so.1
        7f79258ef000-7f7925aef000 ---p 00015000 08:01 10486621 /lib/x86_64-linux-gnu/libgcc_s.so.1
        7f7925aef000-7f7925af0000 rw-p 00015000 08:01 10486621 /lib/x86_64-linux-gnu/libgcc_s.so.1
        7f7925af0000-7f7925c72000 r-xp 00000000 08:01 10486879 /lib/x86_64-linux-gnu/libc-2.13.so
        7f7925c72000-7f7925e72000 ---p 00182000 08:01 10486879 /lib/x86_64-linux-gnu/libc-2.13.so
        7f7925e72000-7f7925e76000 r--p 00182000 08:01 10486879 /lib/x86_64-linux-gnu/libc-2.13.so
        7f7925e76000-7f7925e77000 rw-p 00186000 08:01 10486879 /lib/x86_64-linux-gnu/libc-2.13.so
        7f7925e77000-7f7925e7c000 rw-p 00000000 00:00 0
        7f7925e7c000-7f7925efd000 r-xp 00000000 08:01 10486883 /lib/x86_64-linux-gnu/libm-2.13.so
        7f7925efd000-7f79260fc000 ---p 00081000 08:01 10486883 /lib/x86_64-linux-gnu/libm-2.13.so
        7f79260fc000-7f79260fd000 r--p 00080000 08:01 10486883 /lib/x86_64-linux-gnu/libm-2.13.so
        7f79260fd000-7f79260fe000 rw-p 00081000 08:01 10486883 /lib/x86_64-linux-gnu/libm-2.13.so
        7f79260fe000-7f79261e6000 r-xp 00000000 08:01 920479 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
        7f79261e6000-7f79263e6000 ---p 000e8000 08:01 920479 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
        7f79263e6000-7f79263ee000 r--p 000e8000 08:01 920479 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
        7f79263ee000-7f79263f0000 rw-p 000f0000 08:01 920479 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.17
        7f79263f0000-7f7926405000 rw-p 00000000 00:00 0
        7f7926405000-7f7926407000 r-xp 00000000 08:01 10486882 /lib/x86_64-linux-gnu/libdl-2.13.so
        7f7926407000-7f7926607000 ---p 00002000 08:01 10486882 /lib/x86_64-linux-gnu/libdl-2.13.so
        7f7926607000-7f7926608000 r--p 00002000 08:01 10486882 /lib/x86_64-linux-gnu/libdl-2.13.so
        7f7926608000-7f7926609000 rw-p 00003000 08:01 10486882 /lib/x86_64-linux-gnu/libdl-2.13.so
        7f7926609000-7f7926620000 r-xp 00000000 08:01 10486875 /lib/x86_64-linux-gnu/libpthread-2.13.so
        7f7926620000-7f792681f000 ---p 00017000 08:01 10486875 /lib/x86_64-linux-gnu/libpthread-2.13.so
        7f792681f000-7f7926820000 r--p 00016000 08:01 10486875 /lib/x86_64-linux-gnu/libpthread-2.13.so
        7f7926820000-7f7926821000 rw-p 00017000 08:01 10486875 /lib/x86_64-linux-gnu/libpthread-2.13.so
        7f7926821000-7f7926825000 rw-p 00000000 00:00 0
        7f7926825000-7f7926845000 r-xp 00000000 08:01 10486876 /lib/x86_64-linux-gnu/ld-2.13.so
        7f7926a36000-7f7926a3c000 rw-p 00000000 00:00 0
        7f7926a41000-7f7926a44000 rw-p 00000000 00:00 0
        7f7926a44000-7f7926a45000 r--p 0001f000 08:01 10486876 /lib/x86_64-linux-gnu/ld-2.13.so
        7f7926a45000-7f7926a46000 rw-p 00020000 08:01 10486876 /lib/x86_64-linux-gnu/ld-2.13.so
        7f7926a46000-7f7926a47000 rw-p 00000000 00:00 0
        7fff2aef8000-7fff2af19000 rw-p 00000000 00:00 0 [stack]
        7fff2afff000-7fff2b000000 r-xp 00000000 00:00 0 [vdso]
        Restarting Config
        Note that I simply renamed the existing 4.3 directory and installed the beta version as described. Using
        Safari, I can access the config page.
        Andreas
        • andreash
          • Dec 2014
          • 10
          Additional comment on Debian version:
          Distributor ID: debian
          Description: Debian GNU/Linux 7 (wheezy)
          Release: 7.8
          Kernel: 3.2.0-4-amd64
          Andreas
