Help Required
  • Mission360
    • Nov 2014
    Help Required
    I am banging my head against a brick wall over this and I'm sure the answer is staring me in the face! Quite simply I want to browse all my albums by a certain artist. So for example, "artist" or "album artist" = Daughtry. They have 6 albums for example. When I click on Artist, I then want to see the list of 6 albums. From that, when i then click on the album I want it to list the tracks. At the moment I just see the Artist, then after that it lists all the tracks by the artists. I thought I had tried every configuration possible but still to no avail. I am using the Naim app by the way to control. Thanks in advance for any advice you can offer
    • 46231
    Re: Help Required
    By default, Asset allows browsing:
    Artist >> Album
    It must be the naim app which is removing the Album listings, as a test you can install 'Asset Control' on a PC (it is in the testing section of this forum), or Kinsky on an ipad to browse Asset as it should.
