Could my Asset be Part of My Problem?
  • Tom Swaman
    • Oct 2011
    • 258
    Mr. Spoon,
    My system had been running flawlessly until Friday. We had an instantaneous power outage which shutdown parts of my 3 music systems. I rebooted/reset everything I knew to do and I have my 3 systems playting using a single music storage folder containing all FLAC files, Asset, 3 LINN DS units and LINN Kinsky. I can get the system to work using Kinsky on my computer, but it fails to work using the Kinsky App on any of 3 remote Android devices. I have completely uninstalled the Kinsky Apps and reinstalled these and still the remote devices are not working as these previousl did.
    Mr. Spoon, do you have any thoughts on what is not working and on what I might do to return the 3 Android remotes to working?
    Thank you very much for your thoughts and help.
    Best regards,
    Tom
    • 46233
    Re: Could my Asset be Part of My Problem?
    Try to reboot everything including router and switches.
    • Tom Swaman
      • Oct 2011
      • 258
      Much apprectistion Spoon for your accurate suggestion.
      Best regards,
      Tom
