Help Me With Scanning Please
  • Willliam K
    • Aug 2014
    • 10
    I'm new to Asset and Upnp in general. I have a tower PC running Windows 7 with an SSD for the operating system and a 3TB HDD installed in the tower for storage with all my music files in a folder on the drive labeled Music . I have an ethernet cable to my Denon X4000 AVR from my router and I have Asset Upnp installed on my wireless laptop also running Asset Control. Whenever I add a file to my collection I have to open configuration and Refresh All (which takes a while to do) to see the new file. I think maybe from reading this forum the problem is that the HDD isn't considered a "local drive". Is this correct, and if so is there a shortcut I can use to just detect the changes instead of scanning the whole folder all of the time? Thanks in advance for any help.
    • 46231
    Re: Help Me With Scanning Please
    What about a Refresh Detecting Changes? does that find the track? (keep an eye on track numbers before and after scanning).
    • Willliam K
      • Aug 2014
      • 10
      When I run detect changes the folder shows up but its empty.
        • 46231
        Install Asset Control from here:
        http://forum.dbpoweramp.com/showthre...-Asset-Control
        and see if that shows any files (when using Refresh Detecting Changes), it will allow you to browse asset.
        • Willliam K
          • Aug 2014
          • 10
          Thank you for the help Spoon. I was using Asset Control before but I uninstalled it and did a new install per your link and it is working fine right now. I added a new folder and it showed up without even running a new scan :smile2: Is there a way for me to direct Asset Control to render Zone 2 on my Denon AVR as a player? Maybe I should start another thread since it's unrelated. Thanks again
            • 46231
            The denon should be controllable with asset control.
            • Willliam K
              • Aug 2014
              • 10
              Thanks again for the help Spoon...I guess a direct connection to zone 2 isn't possible because the X4000 is definitely listed as a player but dividing it into zones is probably asking too much as it only has one Ethernet connection.
