Help Relieve Fatigue and Frustration, Please
  • Tom Swaman
    • Oct 2011
    • 258
    I am using the full version of Asset UpNp on a Windows 7 system. I keep ripping, using the CD ripper an album having 13 tracks. The first 12 tracks are written by one composer and the 13th/last track is written by a second composer. All tracks rip as accurate and the album shows in a single complete and proper folder in the music folder. However, in Asset UpNp only the 13th track appears and I cannot find any of the first 12 tracks desoite them being in the music folder.
    I have 3 times repeated this fro scratch with the same results.
    Help please?????
    Many thanks,
    Tom Swaman
    • 46231
    Re: Help Relieve Fatigue and Frustration, Please
    So if you browse:
    Album >> (the name of your album)
    it only shows 1 track?
    Which version of Asset do you have?
    • Tom Swaman
      • Oct 2011
      • 258
      Spoon,
      Thank you and I have Version 4.3.
      Regards,
      Tom Swaman
        • 46231
        So if you browse:
        • Tom Swaman
          • Oct 2011
          • 258
          Spoon,
          That is correct, There are a total of 13 tracks in the album, 12 by one composer and the 13th track by a second composer. Only the latter appeared.
          Regards,
          Tom
            • 46231
            When browsing you are selecting a composer? or just browsing for that album direct?
            • Tom Swaman
              • Oct 2011
              • 258
              Browsing for the album directly or browsing for the artist common to all 13 tracks.
              Tom
                • 46231
                Can you send one album which exhibits this:
                If your files are lossless and you have dBpoweramp, convert the files to low bit rate mp3, then send over the mp3 files please.
                • Tom Swaman
                  • Oct 2011
                  • 258
                  Spoon,
                  On the sixth try of re-ripping, I shortened the track information in tracks 1-12 and then was successful in getting all 13 tracks, i.e. the entire album to be recognized by Assset v. 4.3. Does this now make sense?
                  Thank you,
                  Tom
                    • 46231
                    It is possible these tracks were in different folders?
