Debian Asset Album question(problem?)
  • lg.lindstrom
    • Aug 2010
    • 18
    Hi
    A couple of days ago I installed Asset on a Debian machine. Followed the install instruction without any problems.
    I have a small music library, just for test purposes.
    I noticed that when I listed my "Albums" it shows far to many items (I have 15 Albums, it listed 28).
    A closer examination told me that Titles with different Artists was combined into separate Albums.
    I am not quite sure if this is a configuration problems? ... or?
    Using other DLNA servers on the same library,,,, gives correct result.
    I am using BubbleUPnp control point.
    //regards
    //lg
    Re: Debian Asset Album question(problem?)
    Albums with different Artists need to be tagged as Various Artist albums.
    For these albums, either:
    1. Set the Compilation tag to 1
    2. Set the Album Artist tag to 'Various Artists'
    3. Both of the above
    Personally, I do option 3.
    • lg.lindstrom
      • Aug 2010
      • 18
      Ok.
      Are there a special reson for that.??
      Squeezebox server and minimserver doesent seem to have this "function"?
      I just found another "issue". I added a new album to my library. It shows up under "new albums" but not under "all albums". Strange.
      /lg
        To display albums, music servers (and music players) use different combinations of tags to achieve this.
        I guess Asset uses different tags to Squeezebox etc. to organise the Album list. In my opinion, Assets approach seems very logical.
        ... as a footnote to this, for all Albums (not just compilations), I recommend always using the Album Artist tag as well as the Artist tag
          • 6189
          Ok.
          /lg
          actually squeezeboxes do have this function. The difference is that LMS (squeezebox server) will automatically treat an album with differing track artists as a COMPILATION.
            • 46231
            Asset is more advanced when it comes to albums, however your tags need to be correct. On other media servers, you will find all the tracks grouped together in a single 'Greatest Hits' album, even though you could have 5 such albums which are distinct.
              • 6189
              I should add, LMS will do this *unless* one has added an ALBUM ARTIST tag. Then the album will not show up under COMPILATIONS or VARIOUS ARTISTS unless one also has added the COMPILATION tag with a value of "1". p.s. LMS also handles the "Greatest Hits" problem as well, and like ASSET does not show Greatest Hits of different artists as if they are a single album.
              • lg.lindstrom
                • Aug 2010
                • 18
                Hi.
                I am using Album Artist as my "main" tag. What I mean,, Artist contains all artist that have participated on a track,, and Album Artist are the artist who have "publiced" the album.
                For me it seems like the tag syntax are define,, not the semantics.
                /lg
                  Yes, exactly what I do.
                  ... and for various artists albums I set the Album Artist tag to 'Various Artists' and the Compilation tag to '1', which should fix any album display issues in most music servers/players.
