Asset and Naim streamer problem
  • coop250
    • May 2014
    My Naim streamer works fine with Asset but when I try to play music the next day, I turn on the Mac from its sleep mode but the Naim won't play any music without a power cycle of itself. The folders are still there, I can browse to any track, but when I hit play I get an 'initialising' message and then it goes back to display the root, where you get the 'Asset upnp' name.
    Any ideas why this happens?
    Thanks for any help you can provide.
    coop250
    • 46231
    Re: Asset and Naim streamer problem
    My first guess would be an issue on the Naim player, because the naim player will only have 1 connection to 1 server at anytime. Whereas the UPnP server, could accept 100 new connections for all different tracks, it is like a web server on the Internet.
    • coop250
      • May 2014
      OK thankyou Spoon - I'll push this back to Naim to address.
      • fencing fan
        • May 2014
        • 8
        coop250,
        I don't know if you are on the Naim forum, but many of us are having connection issues with streamers, and UPnP connectivity. When you can't get Asset to play, will the Naim work if you change inputs to iRadio? But I agree that the power cycle approach is often necessary.
        Sometimes I can get my Naim to go if I use the remote and press the 'wrench' key to get to some of the unit settings; sometimes it works, sometimes not. I'm not sure if I understand Spoon's post above, but I can get nStream to show three UPnP servers at at time. Although, sometimes it shows none at all.
