Not running??
  • Imjinman
    • Jun 2012
    • 23
    Not running??
    Hi
    I have recently upgraded my PC to Win 8.1 from Win 7 on a new hard-drive.
    However Status says "Not Running" even though I am pointing at my Music folder. Worked just fine before the move to Win8.1. Am running release 4.1 on Local Account
    I have McAfee but I disabled firewall and virus scanning to no avial
    Any thoughts please?
    BC
    • 46231
    Re: Not running??
    The startup type, what is it set to? for asset.
    • Imjinman
      • Jun 2012
      • 23
      Re: Not running??
      Not sure what you mean by "start up type"- but Asset UpNP Configuration opens up and is set at Local Services
      Thank you
        • 46231
        Re: Not running??
        Try selecting Local Account.
        • Imjinman
          • Jun 2012
          • 23
          Re: Not running??
          That's what I meant- it is set up as local account. I've also clicked restart asset But still says not running
            • 46231
            Re: Not running??
            Do you have any security software which might be stopping Asset from running?
            • Imjinman
              • Jun 2012
              • 23
              Re: Not running??
              I am using McAfee but I disabled it and still Asset doesn't run. Also it worked with McAfee on my old Win 7 PC.
              BTW I also moved across all the files in the Asset folder on my old Win7 drive onto the Win8.1 drive. I wanted to ensure I moved across the database so that i didn't have to start from scratch on renaming, classifying, etc 9,000 songs.
              Thanks for your continued help
                • 46231
                Re: Not running??
                Try reinstalling Asset, as if you upgrade your Windows it will not be installed correctly.
                • Imjinman
                  • Jun 2012
                  • 23
                  Re: Not running??
                  Many thanks, That seems to have worked ....but...now if I go to Dynamics Browsing/Genre the songs etc are not collated under a single Genre. Eg there are hundreds of "Acoutsic" each with only one album in them.
                  Any thoughts?
                    • 46231
                    Re: Not running??
                    You have 'Acoustic' listed 100 tines under Genre (for dynamic, how about when Genre is selected without dynamic)?
                    • Imjinman
                      • Jun 2012
                      • 23
                      Re: Not running??
                      Hi
                      I changed the genre Acoustic to Chilled in Jaikoz, restarted Asset and all seems fine now. Many thanks for your help and all the best for the new year.
