Asset Control in Window
  • Chip
    • Aug 2008
    • 102
    Hello,
    I am running Asset UPnP Full Release Version 4.1 on a computer in one room with an Ethernet connection and Asset Control on my laptop wirelessly in my listening room.
    When I start Asset Control it starts in Full Screen mode. I do not have an option in the top right corner to switch to Window mode.
    Is it possible to have Asset Control run in a Window instead of Full Screen?
    Thank You,
    Chip
    • 45441
    Re: Asset Control in Window
    Yes it is an option in the configuration settings.
    • Chip
      • Aug 2008
      • 102
      Hello,
      I have looked at the Configuration options in Asset UPnP and can not find this option.
      Start Asset UPnP
      click Edit button next to Advanced Settings
      Looked in General Settings
      Can you tell me the name of the option I need to set?
      Thank you,
      Chip
      • Chip
        • Aug 2008
        • 102
        Hi all,
        Does anyone know where this option is to allow Asset Control to operate in a Window on my desktop?
        Thank you,
        Chip
          • 45441
          Ah, Asset control is always full screen, however you can set to keep task bar visible.
          • Chip
            • Aug 2008
            • 102
            Hi Spoon,
            Understood.
            Chip
