Can I capture sound from my PC and "stream" it to my DLNA reciever?
  • havmir
    • Nov 2013
    I'm trying to decide if Asset will perform the service I need. Would appreciate any help rendered.
    I have a Windows 7 PC and a Sony STR DA2800ES DLNA receiver. I also have an internet radio subscription to SiriusXM radio that came along with my vehicle SiriusXM readio subscription.
    I can listen to SiriusXM internet radio on my PC and on my Android device. However, I would like to stream live audio from SiriusXM internet radio from my PC to my Sony STR DA2800ES DLNA renderer/receiver. The receiver has a wifi LAN connection and I have been able to play "static" music and video files from my PC on the DA2800ES reciever.
    Can I use Asset to "stream" the live internet stream playing on my PC speakers (sound card) to my Sony STR2800DA receiver?
    • 46231
    Re: Can I capture sound from my PC and "stream" it to my DLNA reciever?
    Yes it should do, make sure it works for you with the trial.
