Multi Disc Sets & Asset r4.1
  • knirpslinn
    • May 2011
    • 15
    I finally updated to r4.1 and am running into a problem.
    Multi-disc sets only show up as:
    Bitches Brew
    Bitches Brew, Disc 2
    In the past, multi-disc sets showed Disc 1 as well. I checked to be certain that the preference for "Multi-Disc Albums show as 'Album, Disc x'" was checked and I double checked the meta-data to be certain that the first disc of a set was properly tagged - I use the DISCNUMBER and DISCTOTAL fields.
    This just came up when I switched to r4.1
    Any thoughts?
    • 46189
    Re: Multi Disc Sets & Asset r4.1
    There was no need to show , Disc 1 so it was removed...
    • thfc4ever
      • Jan 2012
      I have found some strange behaviour and inconsistencies with multi disc sets after ripping with dbpoweramp 14.3 - With FLAC there is no TOTALDISCS tag, only DISCTOTAL which results in a single merged album with the tracks sorted together e.g. 1,1,1,2,2,2,3,3,3 etc. However, the AAC version of the rips correctly include the TOTALDISCS tag. Took me a good couple of hours to figure out as it was driving me crazy....
      Using WHS v1, Asset 4.1 uPnP streaming to JRiver
      • knirpslinn
        • May 2011
        • 15
        Actually, there is a need to show Disc 1 when dealing with multi-disc sets. Now Disc 1 follows Disc 2, 3, etc. in the lists. This is via Kinsky, PlugPlayer and SongBook Lite on Mac, PC and iOS.
        I'm not certain which email address to use, but I can send you a screenshot.
        Thanks!
          • 46189
          Will fix for R4.2
          • steverose
            • Aug 2009
            • 20
            Any idea when R4.2 will be out?
              • 46189
              Hopefully will put to beta in the next 4 weeks
