Asset Control problems
  • Imjinman
    • Jun 2012
    • 23
    Hi
    I can see all of my music folders, songs etc in Asset Control but the icon next to the track has a red line though the quaver symbol. And I can't play the track. Running Win 7
    All are FLACs
    Thank you
    BC
    • 46231
    Re: Asset Control problems
    It means there is no player selected, or the player is not compatible with flac.
    • Imjinman
      • Jun 2012
      • 23
      Excuse my ignorance, but how do I select a player? The first screen of Asset Control shows the servers. I select Asset UPnP and then go through to select a track, but it has a red line through the icon. I can play the FLAC tracks directly through Media Player
        You could try searching the forum.
        The answer is here:
        http://forum.dbpoweramp.com/showthre...h-it-installed
