Speed of variable listening to wma lossless files converted.
  • pdelange
    • Jan 2013
    I use Asset uPnp with Windows 7 64-bit trial version and the Cambridge Stream Magic 6 drive.
    My wma files are converted to mp3 at 320 Kps because the player does not support wma lossless format.
    After 1 minute and 55 seconds, the sound is choppy as if it advanced on the current track.
    I tried several different output format as the LPCM, etc. but I still have the same problem that occurs more or less quickly after a certain time.
    What is the trial version or is this a problem of conversion on the fly of the wma lossless files?
    • 46231
    Re: Speed of variable listening to wma lossless files converted.
    The cambridge device constantly closes and reopens the stream whist it is streaming (which means transcoding cannot be used as every 10 seconds the whole file has to be reconverted wma >> something else).
    Every other player they open the stream once and read from it until the end.
