stream lag - how can i fix
  • pbyford
    • Jan 2013
    hi,
    i purchased the licenced asset uPnP to stream audio from a windows 7 laptop to a dlna certified device.
    having installed and ran the software and found there is a 2-3 second lag. meaning there is a delay between audio leaving the laptop and audio being output on the dlna device.
    i have purchased the software for the purpose of digital djing, which means i need there to an imperceptible delay. when i make a change to audio on the laptop i need to have the sound output on the dlna device immediately.
    please can you advise how i remove this delay?
    thanks
    paul
    • 46231
    Re: stream lag - how can i fix
    It is not possible to remove this delay as it is needed as a streaming buffer, it is not possible to have zero delay.
